Bluetooth 2.0 Module V3 For Arduino
$18.95
SKU: TEL0026
Purchase this product and earn 190 reward points, which are tied to VIP membership program. Learn More >
DF-BluetoothV3 Bluetooth module uses a unique double-board design, it is beautiful and aim to prevent electrostatic damage to the module. It is designed to have 2 DC power input, wide voltage supply (3.5V ~ 8V) and 3.3V power supply, suitable for various applications. STATE LINK is indicated by a clear and bright LED which is used to display module status and connection status (STATE state: Search state (high 104ms 342ms 2.9Hz cycle flicker) connection status (high 104ms period 2s 0.5Hz flashing), LINK state: paired ). It has build-in on-board antenna which provides high quality signals.
DIP switch is designed to set the module status, LED Off to turn off the LINK light to enter power saving mode, AT Mode allows the module to enter AT command mode, AT commands can modify the baud rate and the master and slave mode.
This module can also be used as a pair which provides a transparent serial data communication.
JavaScript display
Product Name Bluno Bee - Turn Arduino to a Bluetooth 4.0 (BLE) Ready Board
Bluetooth 2.0 Bee Module For Arduino
Bluno Link - A USB Bluetooth 4.0 (BLE) Dongle
Bluetooth Adapter Mini
SKU TEL0073
TEL0026
TEL0023
TEL0087
TEL0002
BLE Chip
 TI CC2540
CSR BC417143
CSR BC417143
 TI CC2540
Frequency
2.4GHz
2.4 ~ 2.48GHz unlicensed ISM band
2.4GHz
2.4 ~ 2.48GHz FHSS
Transfer rate
1Mbps GFSK
Asynchronous: 2.1Mbps (Max) / 160 kbps; Synchronous: 1Mbps/1Mbps
1Mbps GFSK
3Mbps
BLE protocol
V4.0
V2.0 + EDR
V2.0 + EDR
V4.0
V2.0
Modulation
GFSK
GFSK
GFSK
GFSK
FHSS
Power consumption
10.6mA average, ready mode: 8.7mA
Sensitivity
-93dBm
≤-84dBm
≤-84dBm
-93dBm
≤-84dBm
Working Voltage 3.3V
+3.5 V ~ +8 V DC and 3.3V DC/50mA
3.3V
3.3V
Operating temperature
 -40 ℃ ~ +85 ℃
-20 ℃ ~ +55 ℃
-20 ℃ ~ +55 ℃
-10 ℃ ~ +85 ℃
-20℃ ~ +55℃
Transmission distance
30m
20 ~ 30m
20 ~ 30m
10 ~ 20m
<10m
Dimension
32*22mm
40*20*13mm
32*24*9mm
32mm * 16mm
20*16*8mm
Weight (g)
10
10
12
10
10
AT command to debug the BLE
master-salve machine switch
Transparent transmission
Wireless programming
√ (Available for Bluno series)
iBeacons
BLE HID
Mobile App Control
Key Featuressupport Android and IOS applications,open source code,suitable for secondary development by the user
Compatible with APC220 communication interface, can be directly used in I/O Expansion Shield, Romeo, XBoard and etc,.
It can be plugged into the Arduino controller using the XBEE base for Bluetooth wireless control.
Standard USB interface. Support for firmware update via USB. Install Arduino UNO USB driver, default host mode.
USB2.0 standard interface. supports the native Windows Bluetooth stack.
This module has been tested and compatible with most Bluetooth adapter in the market (Bluetooth dongle, including laptops and mobile phones).
This module has been tested and compatible with Android Phones.
  • The Bluetooth chip: CSR BC417143
  • Bluetooth protocol: Bluetooth Specification v2.0 + EDR
  • USB Protocol: USB v1.1/2.0
  • Operating frequency: 2.4 ~ 2.48GHz unlicensed ISM band
  • Modulation: GFSK (Gaussian Frequency Shift Keying)
  • Transmit Power: ≤ 4dBm, Class 2
  • Transmission distance: 20 ~ 30m in free space
  • Sensitivity: ≤-84dBm at 0.1% BER
  • Transfer rate: Asynchronous: 2.1Mbps (Max) / 160 kbps; Synchronous: 1Mbps/1Mbps
  • Safety features: Authentication and encryption
  • Support profiles: Bluetooth serial port
  • Serial port baud rate: 4800 ~ 1382400 / N / 8 / 1 default: 9600
  • LED indicator: STATE state: Search state (high 104ms 342ms 2.9Hz cycle flicker) connection status (high 104ms cycle 2s 0.5Hz flashing), LINK Status: Always after match
  • Input Voltage: +3.5 V ~ +8 V DC and 3.3V DC/50mA
  • Working temperature: -20 ℃ ~ +55 ℃
  • Module Size: 40 × 20 × 13mm(1.6x0.8x0.5'')
  • DFRobot Bluetooth V3    x1
Only 9 Left
$18.95
