XBee S2C ZigBee (Wire Antenna)
$35.00
SKU: TEL0020
Purchase this product and earn 350 reward points, which are tied to VIP membership program. Learn More >
This is the XBee S2CTH ZigBee module with wire antenna. It improves on the transmit power and data protocol which allows you to create complex mesh networks based on the XBee ZB ZigBee mesh firmware. These modules allow a very reliable and simple communication between microcontrollers, computers, systems, really anything with a serial port! Point to point and multi-point networks are supported.
The XBee S2C module has a uniform pin map with other XBee modules, which means you can plug it on the standard Arduino XBee shield, like DFRobot Gravity IO Expansion Shield. It is very convenient for the user to design their own devices.
Feature
  • Interoperable with other ZigBee compliant devices*
  • Supports binding and multicasting, for easy integration into a Home Automation platform
  • Through-Hole and Surface Mount form factors enable flexible design options
  • 15 general-purpose I/O lines
  • Link budgets of 110 dB for XBee
  • Industry leading sleep current of sub 1uA
  • Firmware upgrades via UART, SPI or over the air
    • Data Rate: RF 250 Kbps, Serial up to 1 Mbps
    • Indoor/Urban Range: 200ft (60m)
    • Outdoor/RF Line-of-Sight Range: 4000ft (1200m)
    • Transmit Power: 3.1mW
    • Receiver Sensitivity: -100dBm
    • Serial Data Interface: UART, SPI
    • Configuration Method: API or AT command, local or over-the-air
    • Frequency Band: ISM 2.4GHz
    • Form Factor: Through-Hole, Surface Mount
    • Interference Immunity: DSSS (Direct Sequence Spread Spectrum)
    • ADC Inputs: (4) 10-bit ADC inputs
    • Digital I/O: 15
    • Antenna: Integrated Wire
    • Operating Temperature: -40o C to +85o C
    • Dimensions (L x W x H) and Weight: 0.960 x 1.087 in (2.438 x 2.761 cm)
    XBee S2C ZigBee (Wire Antenna) x1
    Zoolnurain.Zulfiqar Jun 28, 2024
    I got the Original Items.
    Only 4 Left
