8 Channel Relay Module (RJ45-RLY16, Up to 16Amp)
$83.00
SKU: DFR0146
Purchase this product and earn 830 reward points, which are tied to VIP membership program. Learn More >
The ETH008-B provides eight volt free contact relay outputs with a current rating of up to 16Am. The module is powered from a 12vdc supply which can be regulated or unregulated. The DC input jack is 2.1mm with positive core polarity, DC supplies are required to supply at least 500mA at 12vdc. The relays are SPCO (Single Pole Change Over) types.
The normally open, normally closed and common pins are all available on the screw terminals.
The ETH008-B provides a red LED mounted immediately next to each relay to indicate whether it is in a powered state (LED on), there is also two LED's mounted in the Ethernet connector which will flash with Ethernet traffic. Finally there is a green power LED just above the processor.
Relay Rating
 load type   Typical applications   Rating  Max DC load capacity
Ethernet Controlled 8 Channel Relay 16A - DFRobot
 AC1  Non inductive or
 slightly inductive loads
 16A @ 250V AC
 AC15  Control of
 electromagnetic load
 (>72VA)
 3A @ 120V AC
 1.5A @ 240V AC
 AC3  Control of motor   750W
 DC1  Non inductive or
 16A @ 24V DC
 DC13  Control of electromagnetic
 loads
 0.22A @ 120V DC
 0.1A @ 250V DC
  • Controlled over Ethernet using simple TCP/IP commands.
  • Relays - 8
  • Power - 12V DC adaptor, supplied separately.
  • Configuration & Test interface - HTTP (webpage).
  • Control interface - TCP/IP over Ethernet.
  • Relay current - Up to 16Amp @24vdc or 250vac
  • Connections - Screw Terminals for N/O N/C and Common contacts.
  • Free Android and iPhone Apps are available to remotely control this module.
  • Please note additional options such as power supply, case and cables are available separately.
    • Power Supply: 12V@1A
    • Relay: 8
    • Interface: RJ45
    • Protocol: HTTP or TCP/IP over Ethernet
    • Relay current: 16Amp @24VDC/250VDC
    • Dimension: 133*74mm/ 5.23*2.91 inches
    Full ETH008-B Documentation
    Examples:
  • Java - command line application for controlling the module
  • Perl - Simple example of setting an output active/inactive by tcp
  • PHP script - Simple example of setting an output active/inactive by tcp
  • python 2
  • python 3
  • Visual Basic - source code for simple program, includes UDP scan to determine any boards connected to the local network
  • Visual C# - source code for simple program, includes UDP scan to determine any boards connected to the local network
    • Ethernet Controlled 8 Channel Relay 16A (ETH008-B) x1
    Only 19 Left
