2x1A DC Motor Shield for Arduino
$10.90
SKU: DRI0001
  • $10.70 2+ items
  • $10.50 5+ items
  • $10.00 10+ items
This DC Motor shield  for Arduino uses L293 chip which allow to drive two 7-12V DC motors with maximum 1A current each channel. This shield can be directly stacked on standard Arduino Uno and Arduino Mega
JavaScript display
Motor Drive Expansion Board Selection Guide
Product Name 2x1A DC Motor Shield for Arduino
Gravity: Dual Bipolar Stepper Motor Shield for Arduino (DRV8825)
Quad DC Motor Driver Shield for Arduino
SKU DRI0001
DFR0548
DRI0023
DRI0039
Chip
L293B
HR8833
DRV8825
TB6612FNG
Operating voltage
5V DC / 3.3V/5V 2.7~5.5V
Motor drive voltage7-12V DC
3.5~5.5V DC
8.2-45VDC2.5V-13.5V
Maximum drive current
1A each way 1.5A 1.6A
1.2A continuous current (per channel)
2A (continuous pulse)
3.2A (single pulse)
Motor drive using pins
PIN4/5/6/7 (Arduino Controllor)
D4,D5,D6
D7,D8,D12
D3,4,5,6,7,8,11,12
Dimension
56x57mm
63 x 58mm
83*55*25mm
 52mm * 53mm
Weight (g)
60 64 48 24
Frequently used With
FIT0565/FIT0520/
FIT0450/FIT0492/
N20 Series
FIT0565/FIT0520/
FIT0450/FIT0492/
N20 Series
FIT0278/FIT0503
FIT0565/FIT0520/
FIT0450/FIT0492/
N20 Series
Key Features
With motor indicator
8-way servo interface
DC motor x4/stepper motor x2(multiplexed with motor interface)
Full step, 1/2, 1/4, 1/8, 1/16, 1/32 step mode
High-speed drive capability, can drive ordinary 2-phase stepper motor to 5000RPM, and drive quad DC at the same time
Product Name Gravity: IO Expansion & Motor Driver Shield
Gravity: 2x2A Motor Shield for Arduino Twin
TMC260 Stepper Motor Driver Shield
2x2A DC Motor Shield for Arduino
SKU DFR0502
DRI0017
DRI0035
DRI0009
Chip
TB6612FNG
L298
TMC260
L298P
Operating voltage
2.7~5.5V
5V 5V
5V
Motor drive voltage12V (peak value)
4.8 ~ 35V
40V max
6.5~12v(VIN Power Supply),4.8~35V (External Power Source)
3.2A (single pulse)
up to 2A/channel
up to 2A per motor coil
2A
D4 D5 D6 D7
D10,11,12,13
/ Pin 4,5,6,7 are used to drive two DC motor
Dimension
68.5mm×53.3mm
56x57mm
55x55mm
Weight (g)
36 35 35 60
FIT0565/FIT0520/
FIT0450/FIT0492/
N20 Series
FIT0565/FIT0520/
FIT0450/FIT0492/
N20 Series
FIT0278/FIT0503
FIT0565/FIT0520/
FIT0450/FIT0492/
N20 Series
Key Features
Integrated XBee Slot, XBee, WiFi Bee, Bluetooth Bee,  I2C.
Mirrored version of DRI0009.
Drive pins: 10, 11, 12, 13
Not compatible with IO expansion board V7.1. The control port is four, which reduces the overhead of the Arduino digital ports, and easy to program.
Suitable for driving bipolar stepper motors.
SPI serial bus control or STEP/DIR signal control.
Controllers such as Mega with full port expansion.
256 times microstep subdivision.
Use mirror motor to drive DRI0017 to aviod the conflicts . Support PWM speed control. Support PLL advance speed control
  • 2 way 7-12V motor drive
  • Up to 1A current each way
  • PIN 4,5,6,7 are used to drive two DC motors
  • Support PWM speed control
  • 1A Motor Shield  For Arduino  x1
