Arduino Uno Rev 3
$24.90
SKU: DFR0181
This is the new Arduino Uno Rev 3. In addition to all the features of the previous board, the Arduino Uno Rev 3 now uses an ATmega16U2 instead of the 8U2 found on the Uno (or the FTDI found on previous generations). This allows for faster transfer rates and more memory. No drivers needed for Linux or Mac (inf file for Windows is needed and included in the Arduino IDE), and the ability to have the Uno show up as a keyboard, mouse, joystick, etc.
The Arduino Uno R3 also adds SDA and SCL pins next to the AREF. In addition, there are two new pins placed near the RESET pin. One is the IOREF that allow the shields to adapt to the voltage provided from the board. The other is not connected and is reserved for future purposes. The Arduino Uno R3 works with all existing shields but can adapt to new shields which use these additional pins.
Arduino is an open-source physical computing platform based on a simple i/o board and a development environment that implements the Processing/Wiring language. Arduino can be used to develop stand-alone interactive objects or can be connected to software on your computer (e.g. Flash, Processing, MaxMSP). The open-source IDE can be downloaded for free (currently for Mac OS X, Windows, and Linux).
Warnings: The Arduino Uno R3 requires the Arduino 1.0 drivers folder in order to install properly on some computers. We have tested and confirmed that the R3 can be programmed in older versions of the IDE. However, the first time using the R3 on a new computer, you will need to have Arduino 1.0 installed on that machine.  If you are interested in reading more about the changes to the IDE, check out the official Arduino 1.0 Release notes!
  • ATmega328 microcontroller
  • Input voltage - 7-12V
  • 14 Digital I/O Pins (6 PWM outputs)
  • 6 Analog Inputs
  • 32k Flash Memory
  • 16Mhz Clock Speed
Projects
Project 1. Test DFPlayer Mini MP3 Module
Introduction:
Here I'm glad to share an intersting and great project from Stonez, one of our awesome customers. He used our product DFPlayer-A mini MP3 Player to make an excellent MP3 player.
DFPlayer-A mini MP3 Player for arduino
Project 2. How to make a Heart Rate Monitor
Introduction:
This project makes a Heart Beat Detection and Monitoring System using Arduino that will detect the heart beat using the Pulse Sensor and will show the readings in BPM (Beats Per Minute).
Heart Rate Monitor for Arduino
Project 3. Tamaguino Update with Huge OLED
Introduction:
Tamaguino was one of my first Arduino projects and my first game developed to run on a microcontroller.
Project 4. Get Started with 0.5 OLED Display
Introduction:
Do you need a really, really small OLED display Search no more, and check out this tutorial.
Project 5. Get Started with Capacitive Touch Kit Tutorial
Introduction:
Connector board and rainbow cable. The kit only allow the use of one pad at a time connected to the Arduino. To start you will need the touch kit library, available here.
  • Arduino Uno R3 x1
Unveiling the Arduino UNO R4: A Comprehensive Review & Compatibility Guide
Blog Unveiling the Arduino UNO R4: A Comprehensive Review & Compatibility Guide
Oct 10, 2023
Playing GIFs on the Fermion 1.51'' Transparent OLED Display
Projects Playing GIFs on the Fermion 1.51'' Transparent OLED Display
processingh
Oct 10, 2023
Arduino UNO R4 Released! 32-bit Arm Development Boards with Upgraded Performance
Blog Arduino UNO R4 Released! 32-bit Arm Development Boards with Upgraded Performance
Jun 29, 2023
Real life Grand Theft Auto 5 flying Bike(Oppressor MK2)
Projects Real life Grand Theft Auto 5 flying Bike(Oppressor MK2)
Delhi Technology Club
Mar 20, 2023
Arduino UNO Project
Projects Arduino UNO Project
RiverTrue
Feb 27, 2023
Arduino Alarm Clock using DS1307
Projects Arduino Alarm Clock using DS1307
Jainesh.Rathod
Feb 22, 2023
kyle.benson May 10, 2023
Very fast shipping. Thanks!
Arduino Uno Rev 3
$79.90
