Gravity: Analog CH4 Gas Sensor (MQ4) For Arduino
$6.90
SKU: SEN0129
Arduino CH4 gas sensor detects natural gas with adjustable sensitivity. It offers fast response, stability, and plug-and-play compatibility. Dimensions: 40x20mm.
This is an Arduino CH4 gas sensor.  It uses MQ4 probe which is able to detect natural gas, CH4. It is less sensitivity in detecting  alcohol, cooking fumes, and cigarette smoke.
The sensitivity can be adjusted by the potentiometer. The output is proportional to the density of gas. You can use analog reading to read the data from this sensor.
To ease the difficulty of using this sensor,  a Gravity Interface is adapted to allow plug&play.  The Arduino IO expansion shield is the best match for this senor connecting to your Arduino microcontroller
Improvement List
  • Standard assembling structure (Times-of-5mm Center distance between two 3mm(0.12") mounting holes)
  • High quality connector
  • Immersion gold surface
  • Power supply: 5V
  • Interface type: Analog
  • Pin Definition:  1-Output  2-GND  3-VCC
  • High sensitivity to CH4,Natural gas
  • Small sensitivity to alcohol, smoke
  • Fast response
  • Stable and long life
  • Simple drive circuit
  • Size: 40x20mm(1.57"x0.79")
  • Arduino CH4 Gas sensor (MQ4) x1
Jun 26, 2022
Best Collection of 10 micro:bit Robot and IoT Projects to Try in 2023
Projects Best Collection of 10 micro:bit Robot and IoT Projects to Try in 2023
RiverTrue
Nov 08, 2024
Erwan.yudi indrasto Aug 26, 2021
good product
