Gravity: Analog Propane Gas Sensor (MQ6)
$6.90
SKU: SEN0131
Arduino-compatible propane sensor detects LPG, iso-butane, propane. Adjustable sensitivity via potentiometer; fast response, stable, long life. Includes analog cable.
This is an Arduino Propane Gas Sensor. It uses MQ6  probe to detect iso-butane, propane and liquefied petroleum gas (LPG). It is less sensitive with alcohol, cooking fumes and cigarette smoke.
It can be used in gas leakage detecting equipment in consumer and industry applications,
The sensitivity can be adjusted by the potentiometer. The output is proportional to the density of gas. You can use analog reading to read the data from this sensor.
To ease the difficulty of using this sensor,  a Gravity Interface is adapted to allow plug&play.  The Arduino IO expansion shield is the best match for this senor connecting to your Arduino
  • Working Voltage: 5V
  • Interface type: Analog
  • Pin Definition:  1-Output  2-GND  3-VCC
  • High sensitivity to LPG, iso-butane, propane
  • Small sensitivity to alcohol, smoke
  • Fast response
  • Stable and long life
  • Simple drive circuit
  • Size: 40x20mm(1.57"x0.79")
  • Arduino Propane  Gas Sensor (MQ6) x1
  • Gravity Analog Cablex1
Jun 26, 2022
Only 18 Left
