Gravity: MQ9 Gas Sensor - CO & Combustible Gas Detector
$7.50
SKU: SEN0134
  • $7.20 2+ items
  • $6.80 5+ items
  • $6.30 10+ items
The Gravity MQ9 sensor provides reliable detection of carbon monoxide and combustible gases through advanced thermal cycling technology - essential for home safety and industrial monitoring.
Dual-Temperature Detection
Precisely measures CO at low temperature (1.5V) and combustible gases (methane/propane) at high temperature (5V) through controlled thermal cycling.
Wide Detection Range
Accurately detects 10-1000ppm CO and 100-10000ppm combustible gases - covering both safety thresholds and industrial concentration levels.
Gravity Plug-and-Play
Standard 3-pin connector eliminates complex wiring - directly compatible with Arduino and other microcontrollers via analog input.
Adjustable Sensitivity
Built-in potentiometer allows fine-tuning for specific environmental conditions and detection priorities.
To ease the difficulty of using this sensor,  a Gravity Interface is adapted to allow plug&play.  The Arduino IO expansion shield is the best match for this senor connecting to your Arduino microcontroller
  • No external heater circuit required
  • Pre-calibrated for immediate use
  • Compatible with all Gravity expansion boards
  • Low-power operation (150mA max)
  • Cost-effective alternative to electrochemical sensors
  • Home carbon monoxide alarms
  • Industrial gas leak detection
  • HVAC system safety monitoring
  • Smart home air quality systems
  • Laboratory gas concentration analysis
  • Operating Voltage: 5V DC ±5%
  • Output Signal: Analog (0-5V)
  • Detection Range:
              CO: 10-1000ppm
              Combustible Gases: 100-10000ppm
  • Response Time: <30s (CO), <10s (combustible)
  • Sensor Type: Semiconductor (SnO2)
  • Dimensions: 36.4×26.6mm (1.43×1.05")
  • Operating Temp: -10°C to +50°C
  • Wiki Doc
  • Schematic
  • MQ9 Datasheet
  • Arduino CO Gas Sensor (MQ9) x1
  • Gravity Analog Cable x1
    Jun 26, 2022
