2x2A DC Motor Shield for Arduino
$13.90
SKU: DRI0009
  • $13.50 2+ items
  • $13.30 5+ items
  • $13.00 10+ items
Arduino product family is a great learning platform for electronics, programming and robotics. But most projects at some point require mobility. This Arduino motor shield allows for motor control with Arduino right away. Stack up this shield on your controller and drive 2 DC motors with  higher power requirements. Depending on the motor of choice, you can make it fast or handle a higher payload. This Arduino Motor Shield (2A) uses L298P chip which allow to drive two 7-12V DC motors with maximum 2A current. This arduino motor shield can be directly mounted onto standard Arduino Uno and Arduino Mega.
Speed control is achieved through conventional PWM which can be obtained from Arduino’s PWM output Pin 5 and 6. The enable/disable function of the motor control is signaled by Arduino Digital Pin 4 and 7. The Motor shield can be powered directly from Arduino or from external power source. It is strongly encouraged to use external power supply to power the motor shield.
This arduino motor shield is ideal for building Arduino robot or other Arduino motor control projects.
There is another version of 2x2A motor shield (Twin) which uses different pins to avoid conflicting pin allocation.
Compatibility
Motor Drive Expansion Board Selection Guide
Product Name 2x1A DC Motor Shield for Arduino
Gravity: Dual Bipolar Stepper Motor Shield for Arduino (DRV8825)
Quad DC Motor Driver Shield for Arduino
SKU DRI0001
DFR0548
DRI0023
DRI0039
Chip
L293B
HR8833
DRV8825
TB6612FNG
Operating voltage
5V DC / 3.3V/5V 2.7~5.5V
Motor drive voltage7-12V DC
3.5~5.5V DC
8.2-45VDC2.5V-13.5V
Maximum drive current
1A each way 1.5A 1.6A
1.2A continuous current (per channel)
2A (continuous pulse)
3.2A (single pulse)
Motor drive using pins
PIN4/5/6/7 (Arduino Controllor)
D4,D5,D6
D7,D8,D12
D3,4,5,6,7,8,11,12
Dimension
56x57mm
63 x 58mm
83*55*25mm
 52mm * 53mm
Weight (g)
60 64 48 24
Frequently used With
FIT0565/FIT0520/
FIT0450/FIT0492/
N20 Series
FIT0565/FIT0520/
FIT0450/FIT0492/
N20 Series
FIT0278/FIT0503
FIT0565/FIT0520/
FIT0450/FIT0492/
N20 Series
Key Features
With motor indicator
8-way servo interface
DC motor x4/stepper motor x2(multiplexed with motor interface)
Full step, 1/2, 1/4, 1/8, 1/16, 1/32 step mode
High-speed drive capability, can drive ordinary 2-phase stepper motor to 5000RPM, and drive quad DC at the same time
Product Name Gravity: IO Expansion & Motor Driver Shield
Gravity: 2x2A Motor Shield for Arduino Twin
TMC260 Stepper Motor Driver Shield
SKU DFR0502
DRI0017
DRI0035
DRI0009
Chip
TB6612FNG
L298
TMC260
L298P
Operating voltage
2.7~5.5V
5V 5V
5V
Motor drive voltage12V (peak value)
4.8 ~ 35V
40V max
6.5~12v(VIN Power Supply),4.8~35V (External Power Source)
3.2A (single pulse)
up to 2A/channel
up to 2A per motor coil
2A
D4 D5 D6 D7
D10,11,12,13
/ Pin 4,5,6,7 are used to drive two DC motor
Dimension
68.5mm×53.3mm
56x57mm
55x55mm
Weight (g)
36 35 35 60
FIT0565/FIT0520/
FIT0450/FIT0492/
N20 Series
FIT0565/FIT0520/
FIT0450/FIT0492/
N20 Series
FIT0278/FIT0503
FIT0565/FIT0520/
FIT0450/FIT0492/
N20 Series
Key Features
Integrated XBee Slot, XBee, WiFi Bee, Bluetooth Bee,  I2C.
Mirrored version of DRI0009.
Drive pins: 10, 11, 12, 13
Not compatible with IO expansion board V7.1. The control port is four, which reduces the overhead of the Arduino digital ports, and easy to program.
Suitable for driving bipolar stepper motors.
SPI serial bus control or STEP/DIR signal control.
Controllers such as Mega with full port expansion.
256 times microstep subdivision.
Use mirror motor to drive DRI0017 to aviod the conflicts . Support PWM speed control. Support PLL advance speed control
  • Logic Control Voltage:5V (From Arduino)
  • Motor Driven Voltage:6.5~12v(VIN Power Supply),4.8~35V (External Power Source)
  • 2 way motor drive
  • Logic supply current Iss:≤36mA
  • Motor Driven current Io:≤2A
  • Maximum power consumption:25W(T=75℃)
  • Up to  2A current each way
  • Pin 4,5,6,7 are used to drive two DC motor
  • Support PWM speed control
  • Support PLL advance speed control
  • Size: 55x55mm (2.2x2.2 in)
Projects
  • ​2A Motor Shield For Arduino x1
MultiTasking Robot with Devastator Platform
Blog MultiTasking Robot with Devastator Platform
Jul 27, 2015
Jul 28, 2015
$13.90
