Gravity: Analog LM35 Temperature Sensor For Arduino
$4.50
SKU: DFR0023
  • $4.40 3+ items
  • $4.30 5+ items
  • $4.20 10+ items
This is an Arduino Temperature Sensor based on LM35 temperature chip. A Temperature Sensor can be used to detect ambient air temperature.
The LM35 chip is produced by National Semiconductor Corporation and offers a functional range between 0 degree Celsius to 100 degree Celsius with a sensitivity of 10mV per degree Celsius. The output voltage is proportional to the temperature.
It is commonly used as a temperature measurement sensors. It includes thermocouples, platinum resistance, thermal resistance and temperature semiconductor chips, which commonly used in high temperature measurement thermocouples. Platinum resistance temperature used in the measurement of 800 degrees Celsius, while the thermal resistance and semiconductor temperature sensor suitable for measuring the temperature of 100-200 degrees or below, in which the application of a simple semiconductor temperature sensor has good linearity and high sensitivity. The LM35 linear temperature sensor and sensor-specific expansion of Arduino board, in combination, can be very easy to achieve. The LM35 linear temperature sensor pin definitions: (1) Output (2) complex (3) power.
To ease the difficult of using this sensor,  a  Gravity  Interface is adapted to allow plug&play.  The  Arduino IO expansion shield  is the best match for this sound senor connecting to your  Arduino . As this sensor can work at 3.3V which make it compatible with  Raspberry Piintel edison , joule and curie nano
Type Selection of Temperature Sensors
Name Gravity:I2C Non-contact IR Temperature Sensor For Arduino Gravity: Analog LM35 Temperature Sensor For Arduino Gravity: Waterproof DS18B20 Sensor Kit Gravity: DS18B20 Temperature Sensor Gravity: Analog High Temperature Sensor
SKU SEN0226 DFR0023 KIT0021 DFR0024 SEN0198
Operating Voltage 3.3V/5V 3.3V/5V 3.0V~5.5V 3.3V~5V 3.3V~5.5V
Operating Current 2.7μA 2.7μA <3μA <3μA 2.8μA
Operating Temperature -40℃~85℃ -40℃~150℃ -55℃~125℃ -55℃~125℃ 30℃~350°C
Range of temperature measurement 0℃~65℃ 0℃~100℃ -55℃~125℃ -55℃~125℃ -55℃~125℃
Precision of temperature measurement 0.01℃ 0.5℃ 0.5℃ 0.5℃ 0.5℃
Temperature deviation ±0.5℃ ±0.5℃ ±0.5°C ±0.5℃ ±0.5℃
Dimension 30*22(mm) 30*22(mm) 33*22(mm) 22*32(mm) 42*32*18(mm)
Interface Gravity-I2C Gravity-analog Gravity-digital Gravity-digital Gravity-analog
Data type Digit Analog
Digit (unibus) Digit (unibus) analog
Price $8.80 $4.50 $8.00 $4.00 $16.00
Brief introduction
BMP280 Barometer sensor supports Arduino and can measure both temperature and atmospheric pressure.
It can be applied to enhance GPS navigation & coordinate with IMU sensor to realize indoor and outdoor navigation. Compared to the last generation BMP180 barometer sensor, it has a lower power consumption, higher resolution and higher sampling frequency.
Application: Enahnced GPS navigation (e.g. time-to-first-fix improvement, dead-reckoning, slope detection) Indoor navigation (floor detection, elevator detection) Outdoor navigation, leisure and sports applications Weather forecast Health care applications (e.g. spirometry) Vertical velocity indication (e.g. rise/sink speed)
$A Temperature Sensor can be used to detect ambient air temperature, the output voltage is proportional to temperature. It has good linearity and high sensitivity.
Application:Medical treatments Personal controls Industrial controls Aeronautics and astronautics.
Waterproof temperature sensor DS18B20 is widely used in many fields, such as soil temperature measurement, hot tank temperature control etc. It supports multipoint measurement.
Application:
Constant temperature control Industrial system Consumer electronics Thermistorsr Refrigerators Barns Tanks Telecommunication rooms Powerr communication rooms
Cables etc.
A Temperature Sensor can be used to detect ambient air temperature. It can be connect to three-wire in parallel to achieve multipoint temperature measurement.
Application: Constant temperature control Industrial system Consumer electronics Thermistors Refrigerators Barns Tanks Telecommunication rooms Power communication rooms Cables etc.
It used a PT100 resistance type high temperature probe to measure a temperature range between 30-350°C.
Application: Especially for high precision of temperature measurements. Medical treatments Motors Industrials Temperature counts Resistance counts
Name Gravity: i2C BMP280 Barometer Sensor Infrared Thermometer Module Gravity:SHT1x Humidity and Temperature Sensor
Gravity: DHT11 Temperature Humidity Sensor For Arduino
DHT22 Temperature and Humidity Sensor
SKU SEN0206 SEN0093 DFR0066 DFR0067 SEN0137
Operating Voltage 3.3V~5V 3V~5V 3.3V~5V 3.3V~5V +5V
Operating Current 1.2mA 4mA~9mA 2μA 0.5mA~2.5mA 1.5mA
Operating Temperature -40℃~125 ℃ -10℃~50℃ -40℃~128.8℃ 0℃~50℃ -20℃-80℃
Range of temperature measurement -70.01℃~382.19℃ -33℃~220℃ -40℃~128.8℃ 0℃~50℃ -40℃-80℃
Precision of temperature measurement 0.5℃ 2℃(full range) 0.5℃ 2℃ 0.5℃
Temperature deviation ±0.5℃ ±0.6℃ ±0.4°C ±0.1℃ ±0.5℃
Dimension 31.5*18(mm) 12*13.7*35(mm) 32*27(mm) 22*32(mm) 22*32(mm)
Interface Gravity-I2C Digitalx3 Gravity-2-wire digital Gravity-digital Gravity-digital
Data type Digit Digit Digit (unibus) Digit (unibus) Digit (unibus)
Range of humidity measurement NA NA 0-100%RH 20-90%RH 0-100%RH
Humidity deviation NA NA ±4.5%RH ±5%RH ±2%RH
Price $16.00 $49.00 $21.05 $5.20 $9.50
Brief introduction
non-contact measurement uses infra-red radiation to measure the temperature and does not require a direct touch. Additionally, this method of measurement can be read quickly and accurately. This module has a FOV of 35° Wave length 5.5um-14um
Application: Environmental monitor
Home automation Automobile electronics
Airline industry
Military
It is a long distance thermometer specially designed for a high sensitivity, high accuracy, low noise and low power consumption. Wave length:5um-14um This module has a FOV of  26.6°x 2 = 53.2°
Application:
Medical equipment Fire alarm systems telecommunications
It consists of 1 capacitive humidity module and 1 energy gap temperature module, perfect integration of 1 14bit A/D converter and 1 2-wire digital interface.
CMOSens technology makes it of advantages such as low power consumption, fast response, b anti-jamming capacity etc.
Application:
Medical equipment
HVAC
Meteorology
Humidity regulator Dehumidifier
Tests and measurements
Automobile
Automatically control
This sensor includes a resistive element and a sense of wet NTC temperature measuring devices. It has excellent quality, fast response, anti-interference ability and high cost performance advantages. Its signal transmission distance up to 20 meters. These features make it a variety of applications and even the most demanding applications.
Application:
Medical equipment HVAC
Meteorology
Humidity regulator
Dehumidifier Tests and measurements
Automobile
It contains a resistive element and a sense of wet NTC temperature module. Compared to DHT11, it has smaller humidity deviation, faster response, ber anti-interference ability and higher cost performance
Application:
Meteorology Humidity regulator Dehumidifier
Automobile Automatically control
  • Based on the semiconductor LM35 temperature sensor
  • Can be used to detect ambient air temperature
  • Type: Analog
  • Working Voltage: 3.3-5V
  • Sensitivity: 10mV per degree Celcius
  • Functional range: 0 degree Celsius to 100 degree Celsius
Improvement List
  • Standard assembling structure (Times-of-5mm Center distance between two 3mm mounting holes)
  • High quality connector
  • Immersion gold surface
  • Arduino LM35 Temperature Sensor x1
  • Analog Sensor Cable  (SKU:FIT0031) x1
Jul 27, 2017
