Gravity: Digital Tilt Sensor for Arduino / Raspberry Pi
$1.95
SKU: DFR0028
  • $1.85 2+ items
  • $1.80 5+ items
  • $1.75 10+ items
Purchase this product and earn 20 reward points, which are tied to VIP membership program. Learn More >
This is an arduino tilt sensor. It is used to detect orientation. Inside the sensor, there is a ball that make contact with the pins when the case is upright. Tilt the sensor over and the balls don’t touch, thus not making a connection.
Here is the principle of tilt sensor to illustrate how it works:
Arduino Tilt sensor: how it works
Simple plug to our Arduino IO Sensor Expansion Shield, you can make amazing interactive projects.
As this sensor is now woking under 3.3V, it is now able to be compatible with Raspberry Pi. An Arduino Shield for Raspberry Pi B+/2B/3B will make it easy to use.
  • Standard assembling struct (two 3mm holes with multiple of 5cm as interval)
  • High quality connector
  • Immersion gold surface
  • Supply Voltage: 3.3V to 5V
  • Interface: Digital
  • Size:22x30mm (0.87 x 1.18 in)
  • Digital Tilt Sensor For Arduino x1
$20.00
