Gravity: Digital Capacitive Touch Sensor for Arduino
$3.50
SKU: DFR0030
  • $3.40 2+ items
  • $3.20 5+ items
  • $3.00 10+ items
Purchase this product and earn 35 reward points, which are tied to VIP membership program. Learn More >
This arduino digital capacitive touch sensor provides a one-touch style switch on your Arduino project. It uses the most popular capactiive sensing technology which is the same as your mobile phone.
Getting tired with clicking mechanic button? Try this capacitive touch sensor. Right now we can find touch sensor on most electronic device. So upgrade your Arduino project with our new version touch sensor and make it cool!!
This little sensor can "feel" people and metal touch and feedback a high/low voltage level. Even isolated by cloth or paper, it still can feel the touch. The sensitivity will decrease as the isolation getting thick. For detail of usage, please check it's wiki
With this interactive sensor Arduino can feel your touch
To ease the difficulty,  a Gravity Interface is adapted to allow plug&play.  The IO expansion shield is the best match toconnect this sensor with your Arduino. As this sensor can work at 3.3V which make it compatible with Raspberry Piintel edison, joule and curie.
If you want to start playing with sensors, Gravity: 27 Pcs Sensor Kit for Arduino is a great choice for you to learn varieties of sensors.
  • Standard assembling structure (two 3mm holes with multiple of 5cm as interval)
  • High quality connector
  • Immersion gold surface
  • Supply Voltage: 3.3V to 5V
  • Interface: Digital
  • Size:22x30mm (0.87 x 1.18 in)
  • Capacitive Touch Sensor x1
  • Digital cable x1
Dec 21, 2016
Danli
Jan 10, 2024
The Millennium Falcon Audio Visualizer
Projects The Millennium Falcon Audio Visualizer
alankrantas
Feb 20, 2021
