DFRduino UNO R3 - Compatible with Arduino Uno
$12.90
SKU: DFR0216
DFRduino Uno V3.0 from DFRobot is a physical world computing board of small size for academics or development . It is a simple microcontroller board fully compatible with Arduino UNO R3 and Arduino IDE open-source development environment. This environment implements the Processing / Wiring language. Arduino can be used to develop stand-alone interactive objects or can be connected to software on your computer (e.g. Flash, Processing, MaxMSP). The open-source IDE can be downloaded for free (currently for Mac OS X, Windows, and Linux).
This board features the ATmega16U2 programmed as a USB-to-serial converter. An added bonus is that our DFRduino is still using the DIP package AVR Chip. You could remove it to update or reprogram the chip's firmware, or even to place it on a finished, more compact project. The cool thing about our new DFRduino microcontroller is that the headers use different colors to feature I/O ports of different types:
  • Red for Power Section.
  • Blue for Analog I/O.
  • Green for Digital I/O.
These colors match our sensor cables. This makes it really easy to figure out where to connect sensors, or to identify which side is Analog (blue) or Digital (green).
"Arduino Uno" is a microcontroller board based on the ATmega328. It has 14 digital input/output pins (of which 6 can be used as PWM outputs), 6 analog inputs, a 16 MHz crystal oscillator, a USB connection, a power jack, an ICSP header, and a reset button. It contains everything needed to support the microcontroller; simply connect it to a computer with a USB cable or power it with a AC-to-DC adapter or battery to get started.
This board added SDA and SCL pins that are near to the AREF pin and two other new pins placed near to the RESET pin, the IOREF that allow the shields to adapt to the voltage provided from the board. In future, shields will be compatible both with the board that use the AVR, which operate with 5V and with the "Arduino Due" that operate with 3.3V. The second one is a not connected pin, that is reserved for future purposes.
  • Microcontroller: ATmega328 (DIP package)
  • Operating voltage: 5V
  • Input voltage: No external power supply needed when connected to USB or external 7V~12V DC input
  • Output voltage: 5V DC output and 3.3V DC output
  • Clock speed: 16 MHz
  • Bootloader: Arduino Uno
  • Supports USB interface protocol and power supply (no external power source needed)
  • Supports ISP download function
  • Digital I/O pins: 14 (6 are PWM outputs)
  • Analog input pins: 6
  • DC current per I/O Pin: 40mA
  • DC current for 3.3V Pin: 50mA
  • Flash memory: 32 KB (ATmega328)
  • SRAM: 2 KB (ATmega328)
  • EEPROM: 1 KB (ATmega328)
  • Dimensions: 75 x 54 x 15 mm (2.95 x 2.13 x 0.59 inches)
  • Environmental Friendly: Complies with Rohs standards
    • DFRduino Uno V3.0  x1
    DFRobot Arduino-Compatible Microcontrollers Selection Guide
    Blog DFRobot Arduino-Compatible Microcontrollers Selection Guide
    Jul 29, 2020
    Gun Away
    Projects Gun Away
    RoniBandini
    Feb 18, 2025
    How to use wind speed/direction transmitter on Arduino and micro:bit? ——RS485 to UART
    Projects How to use wind speed/direction transmitter on Arduino and micro:bit? ——RS485 to UART
    Meimei
    Jul 01, 2023
    Arduino UNO Project
    Projects Arduino UNO Project
    RiverTrue
    Feb 27, 2023
    Make a TDS Detector for Water Testing Experiment
    Projects Make a TDS Detector for Water Testing Experiment
    Frances
    Sep 15, 2022
    May 23, 2022
    Dave.Kriedeman Feb 20, 2021
    jérémi.darien May 10, 2025
    This is an amazing product
