Romeo V2 - a Robot Control Board with Motor Driver (Compatible with Arduino)
$26.90
SKU: DFR0225
  • $26.00 2+ items
  • $25.50 5+ items
  • $25.00 10+ items
Purchase this product and earn 269 reward points, which are tied to VIP membership program. Learn More >
Romeo V2 - a Robot Control Board with Motor Driver (Compatible with Arduino), it is especially designed for robotics applications and extended devices. Romeo benefits from the Arduino open-source platform, it is supported by thousands of open source projects, and can easily be expanded with Arduino compatible Shields. The integrated 2 way DC motor driver and Xbee socket allows you to start your project immediately without the need for an additional motor driver or wireless shield.
Another improvement of Romeo V2 is that it supports stepper motor control.
Romeo V2 - a Robot Control Board with Motor Driver (Compatible with Arduino) behaves like Arduino Leonardo based on the ATmega32u4 chip, You can program it directly from the Arduino IDE 1.0.1 or later version. Because of the ATmega32U4 as it's the sole microcontroller, Romeo V2 is simple and easy to use. The 32U4 chipset handles the USB directly, code libraries are available which allow the board to emulate a computer keyboard, mouse, and more using the very interesting USB-HID protocol!  The best advantage is that ATmega32u4 has two serial ports that allow uploading sketches without removing wireless modules.  Debugging is no longer a painful task.
Version History
  • Romeo V2 also improves the power supply, it has now a switch to select power source either from USB or external power.
  • Romeo V2.2 redesigns the power supply system to improve the stability of the ADC circuit.
DFRobot Microcontroller Selection Guide
Model DFRduino UNO DFRduino Leonardo DFRduino Mega2560 DFRduino Mega1280 Romeo V1 Romeo V2 Bluno Wido
SKU DFR0216 DFR0221 DFR0191 DFR0003 DFR0004 DFR0225 DFR0267 DFR0321
Processor ATmega328 ATmega32u4 ATmega2560 ATmega1280 ATmega328 ATmega32u4 ATmega328 ATmega32u4
Board Type Arduino UNO Arduino Leonardo Arduino Mega 2560 Arduino Mega Arduino UNO Arduino Leonardo Arduino UNO Arduino Leonardo
Operating Voltage (Voltage / Input Voltage) 5 V/7-12 V 5 V/7-12 V 5 V/7-12 V 5 V/7-12 V 5 V/7-12 V 5 V/7-20 V 5 V/7-12 V 5 V/7-12 V
CPU Frequency 16MHz 16MHz 16MHz 16MHz 16MHz 16MHz 16MHz 16MHz
Analog Ports  (Input / Output) 6 / 0 12 / 0 16 /  0 16 / 0 6 / 0 12 / 0 6 / 0 12 / 0
Digital Ports (IO/PWM 14 / 6 20 / 7 54 / 15 54 / 15 14 / 6 20 / 7 14 / 6 20 / 7
EEPROM[KB] 1 1 4 4 1 1 1 1
SRAM[KB] 2 2.5 8 8 2 2.5 2 2.5
Flash[KB] 32 32 256 128 32 32 32 32
USB Interface A-B Micro A-B A-B A-B Micro Micro Micro
UART 1 2 4 4 1 2 1 2
Dimension 75 × 55mm 75 × 55mm 108 × 54mm 108 × 54mm 100 × 80mm 89 × 85mm 75 × 55mm 75 × 55mm
Price $19.90 $19.90 $24.90 $14.00 $29.50 $34.95 $24.90 $29.90
*Designed for domestic Arduino fans. Full compatible with Arduino UNO R3.
*Suitable for Arduino Beginners.
*Low-cost main controller board. The main difference from the official one is that this board offers XBee socket and SPI directly-plugged interface, making the best of UART ports.
*For low-cost project, and Arduino communication module development.
*DFRduino Mega 2560 comes with plenty of IO ports, 54 digital ports, 16 analog ports, and 4 UARTs.
*Applicable to large projects that require many sensors.
*Mega1280  has as many IO ports as Mega256 but comes with a smaller Flash. Besides, its price is lower than Mega2560.
*Suitable for low-cost projects requiring many sensors.
*Romeo V1 is specially designed for robot fans. It integrates motor driver, all sorts of communication ports, IO expansion port, and so on.
*Extremely suitable for robot fans.
*The only difference between V1 and V2 is that Romeo V2 adopts ATmega32u4 chip, which provides 2 UARTs, convenient for wireless communication.
*For robot fans to build up projects with wireless communication.
*The first Arduino compatible controller board that integrates Bluetooth 4.0, brings much more flexibility and possibility for Android and IOS mobile development.
*For Android and IOS mobile App BLE developers.
*Integrated CC3000 wifi core and SD card function. Can store a large number of collected data. Compared with Wifi shield, wido is more lightweight and low-cost.
*For IoT developers.
features
  • Wide operating input voltage
  • Directly support Xbee and XBee form factor wifi, Bluetooth, and RF modules
  • ON/ OFF switch to control the system power from external motor power
  • 3 Digital I/O extensions (D14-D16)
  • S1 - S5 switch replace jump cap, allows free use for the GPIO.
  • Micro USB instead of A-B USB connector
  • Analog sensor extension port: Orange for Signal, Red for Vcc, Black for GND
Note: The analog sensor port pin mapping on Romeo v2 is different from the old version.  Please select the "Arduino Leonardo" when using "Arduino IDE".
  • DC Supply: USB Powered or External 6V ~ 23V DC
  • DC Output: 5V(2A) / 3.3V DC
  • Motor driver Continuous Output Current:  2A
  • Microcontroller: ATmega32u4
  • Bootloader: Arduino Leonardo
  • Compatible with the Arduino R3 pin mapping
  • Analog Inputs: A0-A5, A6 - A11 (on digital pins 4, 6, 8, 9, 10, and 12)
  • PWM: 3, 5, 6, 9, 10, 11, and 13. Provide 8-bit PWM output
  • 5 key inputs for testing
  • Auto-sensing/switching external power input
  • Serial Interface
    • TTL Level
    • USB
  • Support Male and Female Pin Header
  • Built-in Xbee socket
  • Integrated sockets for APC220 RF Module and DF-Bluetooth Module
  • Three I2C/TWI Interface Pin Sets (two 90°pin headers)
  • Two-way Motor Driver with 2A maximum current
  • One Stepper Motor Drive with 2A maximum current
  • Size: 89 x 84 x 14mm (3.50 x 3.31 x 0.55")
  • Romeo V2-All in one Controller x1
