Gravity: Analog Rotation Potentiometer Sensor for Arduino - Rotation 300°
$2.90
SKU: DFR0054
  • $2.80 2+ items
  • $2.70 5+ items
  • $2.50 10+ items
This is an Arduino rotation potentiometer , it is able to rotate up to 300-degree.  With the Arduino IO expansion board, in combination, it can be very easy to achieve position-dependent interaction with the rotating effect or produce MIDI instrument. So with this sensor, you can learn how rotary potentiometer works and what analog signal is. You can have much fun with this basic input device.
Gravity Interface is adapted to allow plug&play.  The IO Sensor Expansion Shield is the best match for this sound senor connecting to your Arduino. As this sensor can work at 3.3V which make it compatible with Raspberry Piintel edison, joule, and curie.
Improvement List
  • Standard assembling structure (Times-of-5mm Center distance between two 3mm mounting holes)
  • High-quality connector
  • Immersion gold surface
Gravity:Analog Rotation Potentiometer Sensor V1 For Arduino Demo Project 1
Rotating this sensor can input different voltage which can change Brightness of this LED.
Gravity:Analog Rotation Potentiometer Sensor V1 For Arduino Demo Project 2
What is potentiometer?
"A potentiometer is an instrument for measuring the potential (voltage) in a circuit. A fraction of a known voltage from a resistive slide wire is compared with an unknown voltage by means of a galvanometer. The sliding contact or wiper of the potentiometer is adjusted and the galvanometer briefly connected between the sliding contact and the unknown voltage. The deflection of the galvanometer is observed and the sliding tap adjusted until the galvanometer no longer deflects from zero. At that point the galvanometer draws no current from the unknown source, and the magnitude of voltage can be calculated from the position of the sliding contact."
Analog Rotation Potentiometer Sensor V1 For Arduino Related Projects:
How to Build A Smart Cooling Fan with Arduino?
  • Supply Voltage: 3.3V to 5V
  • Interface type: Analog
  • 300 degree rotation sensor
  • Size:22x31mm (0.87x 1.2 in)
Best Collection of 10 micro:bit Robot and IoT Projects to Try in 2023
Projects Best Collection of 10 micro:bit Robot and IoT Projects to Try in 2023
RiverTrue
Nov 08, 2024
Arduino Alarm Clock using DS1307
Projects Arduino Alarm Clock using DS1307
Jainesh.Rathod
Feb 22, 2023
The Millennium Falcon Audio Visualizer
Projects The Millennium Falcon Audio Visualizer
alankrantas
Feb 20, 2021
