Gravity Interface is adapted to allow plug&play. The IO Sensor Expansion Shield is the best match for this sound senor connecting to your Arduino. As this sensor can work at 3.3V which make it compatible with Raspberry Pi, intel edison, joule, and curie.
Improvement List
Rotating this sensor can input different voltage which can change Brightness of this LED.
What is potentiometer?
"A potentiometer is an instrument for measuring the potential (voltage) in a circuit. A fraction of a known voltage from a resistive slide wire is compared with an unknown voltage by means of a galvanometer. The sliding contact or wiper of the potentiometer is adjusted and the galvanometer briefly connected between the sliding contact and the unknown voltage. The deflection of the galvanometer is observed and the sliding tap adjusted until the galvanometer no longer deflects from zero. At that point the galvanometer draws no current from the unknown source, and the magnitude of voltage can be calculated from the position of the sliding contact."
Analog Rotation Potentiometer Sensor V1 For Arduino Related Projects:
How to Build A Smart Cooling Fan with Arduino?
Project 2: Power outages anticipation device ready for Maker Faire Rome
Introduction: Edenoff, a TinyML Arduino device was modified for secure and interactive demos at Maker Faire Rome 2022
