The Cherokey 4WD mobile robot is a versatile jeep compatible with Arduino boards, featuring a motor driver, prototyping areas, and suitable for competitions and research.
Purchase this product and earn 669 reward points, which are tied to VIP membership program.
Learn More >
The expansion plate board significantly increases the surface area of Cherokey, allowing you to easily connect a 9g micro servo or a standard sized servo in two different locations so that you can install robotic arm or ultrasonic/ir sensors. The prototyping area makes you convenient to install sensors on the robot. Double-side leaf pads solder prototyping areas in the middle can be soldered with DIP components or SMD components to extend addition function.
Its high-strength aluminum alloy body material provides flexibility in rapid movement particularly in outdoor grass, gravel, sand, or sloped surface. The Cherokey 4WD Mobile robot Platform is also suitable for robot competitions and research-related projects.
