Flexible Solar Panel (1.5v 250mA)
$12.90
SKU: FIT0333
  • $12.80 2+ items
  • $12.60 5+ items
  • $11.90 10+ items
Light, thin and versatile solar panel at 1.5V/250MA. Unlike regular solar panels, it is truly flexible to be bent, sewed or treated in the clothing to match any kind of surface line. A good choice for DIY enthusiasts in selecting an alternative power source. Clean energy, in a compact size and a versatile form.
The black edges can be easily cut or sewed, and the solar panel is waterproof.
  • Travelling
  • Business office
  • Outdoor camping
  • Operating Voltage: 1.5V
  • Operating Current: 250mA
  • Open circuit voltage: 2.0V
  • Short circuit current: 420mA
  • Power: 0.5W
  • Use of the environment: -40 ℃ ~ 80 ℃
  • Performance: corrosion, moisture
  • Size: Length 165mm (plus black edges 195mm) X Width 38mm (plus black edges 58mm) X thickness 0.5mm.
  • Weight: 18 g ± 2 grams.
  • Packaging Material: durable, high transmittance ETFE film
  • Adhesive: weather, high transmittance fast curing EVA film
  • Battery Type: Flexible triple junction amorphous silicon thin film solar cells
  • Note: The above refers to the electrical performance parameters measured under standard test conditions, namely: light intensity 1000W / ㎡, spectrum AM1.5, cell temperature 25 ℃.
  • Flexible Solar Panel(1.5V 250mA)   x1
Frances
Oct 25, 2021
Out Of Stock
$34.90
