Forum >how did create ph meter voltage formula ???
userHead anonymous 2018-07-13 04:33:10 2006 Views1 Replies
Hi, my name umarjunaid i have your ph meter module and sample arduino code.i review it for understanding but i can't find how do you come up with volatge formula pHValue = 3.5*voltage+Offset;. and if we are using 3.3v microcontrol then this formula changes or not please tell me
2018-07-14 00:55:47 If you use 3.3V board, then the code need to be changed to "voltage = avergearray(pHArray, ArrayLenth)*3.3/1024;". the number 3.5 is because the output of the probe is -0.4V~0.4V, after amplification, it become 0~4V correspond to pH 0~14, 14/4 =3.5. userHeadPic robert.chen
