Forum >micro:bit Circular RGB Expansion board
userHead Account cancelled 2018-08-08 08:05:47 3515 Views1 Replies
I recently purchased this unit. I am totally unable to get either Windows or OSX to recognize this device as a drive. I have tried various known correct USB cables with no luck. The on/off switch does illuminate the red led but zero response. Is there some kind of little trick here?
2018-08-08 19:25:11 To use the expansion board, you need to add the library in your microbit program environment, can your microbit upload the code successfully? userHeadPic robert.chen
