Forum >MIND+ v1.56 Translation of Extensions
Mind+General
userHead anonymous 2019-07-13 13:07:37 8284 Views1 Replies
Translation of Extensions do not show when the translation xlsx file is loaded.
Loading the file erases the already loaded Extensions and when a new one is loaded, it shows in English only.
There is no way to test the completed translations.
Thx.
2023-05-11 12:19:04
One possible explanation for this issue is that the XLSX file being used may not have the correct formatting or structure to properly load the translated extensions. It's also possible that there is a bug or issue with the data annotation tool being used that is causing the problem.
To troubleshoot this issue, it may be helpful to consult the documentation or support resources for the data annotation tool being used. Additionally, it may be helpful to double-check the formatting and structure of the XLSX file to ensure that it is compatible with the tool.
userHeadPic NicholasWallace
