Forum >Sen0161 with MKR1010
Hi, very new to all this so please bear with me.
I have a MKR1010 and Sen0161 pH sensor which I am struggling to get sensible readings from. I started with the standard DF robot code from here. https://wiki.dfrobot.com/PH_meter_SKU__SEN0161_
Can anyone help with the code for the 3.3v MKR board? I have looked at analogreadresolution because 12 bit and 1023/4093 numbers in the code but don't understand the code and boards enough to write it correctly.
hope you can help and thanks in advance.
Russ
Russ
2020-12-04 22:31:19 Popeye’s Survey Survey offering a great chance to win a validation code to the selected winner who is the customer of Popeye’s and take Popeye’s customer satisfaction survey https://internetfeedback.club/popeyes-survey/
smitavolly
2020-11-26 00:45:02 There should be no difference between MKR1010 and ordinary Arduino development board in terms of pin reading. If our sample program does not help you, you can contact our customer service
347945801
