Forum >How to calibrate probe by exposing it to air. Using Gravity Analog Dissolved Oxygen Sensor.
TroubleshootingArduino
userHead Account cancelled 2022-03-20 00:25:59 1241 Views1 Replies
Hello, even though the method of calibrating the sensor by exposing it to air is not very accurate, I would like to see what the error percentage is.
For this procedure, could you please let me know what the PPM of air to be considered is? I am reading 5.4 to 6.0 PPM by exposing my probe to air. I know it is temperature and pressure dependent. Is there a formula I could use? Thank you.
2025-02-21 08:29:22
Hi! were you able to calibrate the DO sensor? If so, how? I have a similar project just like yours.
userHeadPic Coby.Anupol
