Forum >Maqueen v1 (Original)
userHead Account cancelled 2022-03-21 13:19:16 1230 Views1 Replies
Does the original Maqueen allow servo control? This is the version with the 2x4 pin header for ultrasound sensor and "DC+-" in the lower 4 pins of the header. I cannot find documentation for those other pins. Could I use those pints for servo control?
This version has the power switch on the left and buzzer switch on the right when looking at it for the top and was powered by three AAA batteries.
Thank you for your response in advance,
MAB
2022-04-26 17:49:37
Check out the diagram,  the servo port is at the left of the Maqueen.
userHeadPic R2D2C3PO
