Forum >how to rename ID of learnt object and trigger LED
How to selectHUSKYLENS
userHead Altafrehmani 2022-05-14 22:36:47 4533 Views3 Replies
complete newcomer to Husky lens -
I want to  accomplish the following"
 learn 3 new objects and instead of default IDs have my own custom IDs instead.
Have a LED or any LIGHT turn On once these objects are detected.
what else do i need to accomplish the two above.
(I can code)
regards
2022-07-26 01:52:33
https://github.com/HuskyLens/HUSKYLENSArduino
This github has all the program related info for the HL.
userHeadPic tguneysu
2022-05-15 09:54:50
hi - Thanks for the respond. Not clear how I can change the IDs programmatically and what would I need to do so.
userHeadPic Altafrehmani
2022-05-15 04:26:20
-  learn 3 new objects and instead of default IDs have my own custom IDs instead.
You can do this manually by pushing buttons on the unit, or programmatically by using the command
userHeadPic anonymous
