Is it possible to increase the measurement frequency of these sensors: 5.8GHz Microwave Radar Module (SKU:SEN0521) and
24GHz mmWave Radar (SKU:SEN0395) (make the update refresh rate more than 1Hz)?
Thank you!
2023-02-24 17:31:02
5.8GHz Microwave Radar Module (SKU:SEN0521) and 24GHz mmWave Radar (SKU:SEN0395) can do a higher fresh rate in hardware. However, due to the consideration of accuracy, the minimum delay time is 1 second. Sorry that you can not get a higher fresh rate.
