Forum >AT Command Control Of Player Pro
userHead GaryGranai 2023-02-25 05:41:21 483 Views5 Replies
I want a dfPlayer pro to start playing immediately when it is powered.
I have removed the Prompt.
Currently I use an Arduino Nano with the play on startup sketch.
I would like to eliminate the NANO.
The Wiki indicates the player can be controlled using AT Command Control. I expect that that means an arduino is not required.
What AT Command should I enter to have the player start as soon as it is powered?
Thank you for any help.
Kartonman
2023-03-09 07:42:16
You can try to set play pin to high to start play when it is powered
userHeadPic R2D2C3PO
2023-03-09 07:30:53
Hi, I have tried all the ways I found online to remove the “Music” voice prompt - how did you do it please??
userHeadPic simonwhetham
R2D2C3PO wrote:
try this link https://www.dfrobot.com/forum/topic/315182
2023-03-09 07:44:04
2023-02-28 23:37:22
Yes, you can use AT command to control the Fermion: DFPlayer Pro - A mini MP3 Player.
However, there is no command that can support you to have the player start as soon as it is powered.
You have to use a microcontroller for this function, sorry for that.
userHeadPic NeloKin
