Forum >Connecting SEN0311 to PRODINo MKR Zero
General Arduino
userHead Yovel 2023-02-28 23:03:33 469 Views2 Replies
Hey :D
I am trying to use this SEN0311 Ultrasonic sensor
A02YYUW Waterproof Ultrasonic Sensor Wiki - DFRobot
I want to connect it to this Arduino based board
PRODINo MKR Zero Ethernet V1 - KMP Electronics Ltd
Does anyone knows if it is possible to connect the sensor to this board?
I saw the example for SEN0311 sensor are using “SoftwareSerial” library which is not supported by the PRODINo
so I don't really know how to get things running.
Thanks for any helpers
2023-03-01 18:43:39
HI
A02YYUW Waterproof Ultrasonic Sensor (SKU:SEN0311) use UART communication in TTL protocol. Which means that any device with serial port(TTL protocal) can communicate with this senor.
Could you please check the datasheet of PRODINo MKR Zero, and replace the software serial to a hardware one, and that should work.
Hope it can help.
userHeadPic NeloKin
Yovel wrote:
Hey
Yes from what I understand I do have 2 hardware pins that I can use for the sensor.
But what code I should use to operate it?
Thank you
2023-03-10 06:05:30
