Forum >LattePanda 2 Delta 432 Touch Feature not working
userHead arif.anwar 2023-05-17 16:56:30 1583 Views8 Replies
Hi Support
We purchased a LattePanda 2 Delta 432 with 7"eDP Touch Display (see below). We followed the instructions given on the DFRobot website, and the display works great, images are excellent, but the touch feature does not work at all
https://www.dfrobot.com/product-1853.html
I have tried to update the GoodIX Touch driver as well, but that did not work either. Would you have any suggestions?
Regards
Arif
2024-08-03 04:35:49
Maybe you need a replacement.
userHeadPic lia.ifat
2023-05-25 23:18:22
I have a LATTEAPAND Alpha M3-8100Y, but after installing the auto-on bios, [retro bowl](https://retrobowlgo.com/) the power turns on but the computer does not boot.
userHeadPic Mike.Alley
Mike.Alley wrote:
Nothing appears on the screen when I connect the monitor via HDMI.
[url=https://retrobowlgo.com/]retro bowl[/url]
“retro bowl”:https://retrobowlgo.com/.
[[https://retrobowlgo.com/|retro bowl]]
[link=https://retrobowlgo.com/]retro bowl[/link]
2023-05-25 23:20:46
2023-05-24 17:03:19
Hi Xingzhao, for some reason the “Touch” feature was “disabled” in the BIOS of my Panda. Once “enabled”, now the screen works great. Thank you for your help.
userHeadPic arif.anwar
ISAVSERVICES wrote:
como hizo esta verificacion puede darme unos paso para yo revisar mi problemas
2024-08-02 21:03:18
2023-05-24 17:01:33
Hi Xingzhao..for some reason, the Touch feature was “disabled” in the BIOS of my LattePanda. Once “enabled”, the screen works great  now. Thank you
2023-05-17 17:19:30
Hello Arif,
I would recommend that you check the connection of the touch panel cable, which is shown below.
If the display works fine then there is a high chance that the screen itself is intact. Try to disconnect the touch cable and then reconnect it and see if that helps.
Best Regards,
Xingzhao
userHeadPic xingzhao.zhu
arif.anwar wrote:
Hi, Ive tried to disconnect the touch cable and then reconnect, but it has not helped. There are test points to the touch connector, when I touch the screen, there is no activity on any of the test points. Looks like a driver problem??
2023-05-24 16:01:05
