Forum >Need Urm14 and Rs485 Shield hardware and Arduino codes
General Arduino
userHead Dieudonné.SAMA 2023-06-11 16:57:39 820 Views2 Replies
Hello, I hope you're fine.
I've bought the urm14 module and I need the RS485 shield to use it. By the way I need two more urm14. So in total, I want four(4) Rs485 shield  (https://wiki.dfrobot.com/Arduino_RS485_Shield_SKU__DFR0259) and two (2) urm14 (https://wiki.dfrobot.com/URM14_RS485_Precision_Ultrasonic_Sensor_200KHz_SKU_SEN0358). Please follow the links to see the characteristics. Thank you.
SAMA Dieudonné from Burkina Faso
2023-06-13 02:07:20
Maybe you can try using a shield and multiple Urm14. Please note that when reading sensor data, add a delay function.
userHeadPic jenna
2023-06-11 18:44:19
Sample codes are already given in the links that you've given.Are you looking for a modified code?
