Attempting to drive SER0047 with an Arduino
Hi All,
I am attempting to drive SER0047 servo motor with an Arduino the code is:
#include <Servo.h>
Servo myServo;
int servoPin = 2;
uint16_t i = 0;
void setup() { // put your setup code here, to run once:
myServo.attach(servoPin);
pinMode(LED_BUILTIN, OUTPUT);
// put your main code here, to run repeatedly:
//HERE:
i = 0;
for(i = 1; i <= 180; i++)
myServo.write(i);
delay(15);
for(i = 180; i >= 1; i--)
myServo.write(i);
delay(15);
//goto HERE;
I have verified the servos with a pulse generator so they are working. Is the issue with trying to use the servo library?
Any ideas?
Thanks Glenn
Update: The servo wouldn't start rotation unless given manual help and even then in one direction only..?
