Forum >Gravity GNSS positioning system V1.0 not working correctly!
TroubleshootingGravity
userHead VeeBee 2023-07-18 05:49:27 1329 Views5 Replies
Hi there,
Just set up my new Gravity GNSS positioning system V1.0, everything seems fine except latitude and longitude direction appears to be reversed.
longitude degrees and latitude degrees are correct.
The code below prints correctly but notice I had to swap direction variables.
 Serial.print("latitude = ");
 Serial.print(lat.latitudeDegree,6);
 Serial.print(" degrees ");
 Serial.println((char)lon.lonDirection);
 Serial.print("longitude = ");
 Serial.print(lon.lonitudeDegree,6);
 Serial.println((char)lat.latDirection);
Below is the print out.
Also what is gnss.setRgbOn();?  and why is “ Course over ground = 198.36” when it is not moving?
Thank you
Vaughn
2024-01-20 19:18:06
Hi, What is RGB On used for? thanks
userHeadPic Alfonso.Sainz
2023-07-18 22:37:18
Hi Jenna,
Below is the example code from the DFrobot GNSS library ‘getGNSS’
[code]/*! * @file  getGNSS.ino * @brief Get gnss simple data * @copyright Copyright (c) 2010 DFRobot Co.Ltd (https://www.dfrobot.com) * @license The MIT License (MIT) * @author ZhixinLiu(zhixin.liu@dfrobot.com) * @version V1.0 * @date 2023-03-07 * @url https://github.com/dfrobot/DFRobot_GNSS */
#include "DFRobot_GNSS.h"
#define I2C_COMMUNICATION  //use I2C for communication, but use the serial port for communication if the line of codes were masked
#ifdef  I2C_COMMUNICATION DFRobot_GNSS_I2C gnss(&Wire ,GNSS_DEVICE_ADDR);#else/* ---------------------------------------------------------------------------------------------------------------------*    board   |             MCU                | Leonardo/Mega2560/M0 |    UNO    | ESP8266 | ESP32 |  microbit  |   m0  |*     VCC    |            3.3V/5V             |        VCC           |    VCC    |   VCC   |  VCC  |     X      |  vcc  |*     GND    |              GND               |        GND           |    GND    |   GND   |  GND  |     X      |  gnd  |*     RX     |              TX                |     Serial1 TX1      |     5     |   5/D6  |  D2   |     X      |  tx1  |*     TX     |              RX                |     Serial1 RX1      |     4     |   4/D7  |  D3   |     X      |  rx1  |* ----------------------------------------------------------------------------------------------------------------------*//* Baud rate cannot be changed */ #if defined(ARDUINO_AVR_UNO) || defined(ESP8266)   SoftwareSerial mySerial(4, 5);   DFRobot_GNSS_UART gnss(&mySerial ,9600); #elif defined(ESP32)   DFRobot_GNSS_UART gnss(&Serial1 ,9600 ,/*rx*/D2 ,/*tx*/D3); #else   DFRobot_GNSS_UART gnss(&Serial1 ,9600); #endif#endif
void setup(){ Serial.begin(115200); while(!gnss.begin()){   Serial.println("NO Deivces !");   delay(1000); }
 gnss.enablePower();      // Enable gnss power
/** Set GNSS to be used *   eGPS              use gps*   eBeiDou           use beidou*   eGPS_BeiDou       use gps + beidou*   eGLONASS          use glonass*   eGPS_GLONASS      use gps + glonass*   eBeiDou_GLONASS   use beidou +glonass*   eGPS_BeiDou_GLONASS use gps + beidou + glonass*/ gnss.setGnss(eGPS_BeiDou_GLONASS);
 // gnss.setRgbOff(); gnss.setRgbOn(); // gnss.disablePower();      // Disable GNSS, the data will not be refreshed after disabling  }
void loop(){ sTim_t utc = gnss.getUTC(); sTim_t date = gnss.getDate(); sLonLat_t lat = gnss.getLat(); sLonLat_t lon = gnss.getLon(); double high = gnss.getAlt(); uint8_t starUserd = gnss.getNumSatUsed(); double sog = gnss.getSog(); double cog = gnss.getCog();
 Serial.println(""); Serial.print(date.year); Serial.print("/"); Serial.print(date.month); Serial.print("/"); Serial.print(date.date); Serial.print("/"); Serial.print(utc.hour); Serial.print(":"); Serial.print(utc.minute); Serial.print(":"); Serial.print(utc.second); Serial.println(); Serial.print("latitude Direction  "); Serial.println((char)lat.latDirection); Serial.print("longitude Direction  "); Serial.println((char)lon.lonDirection);  // Serial.print("lat DDMM.MMMMM = "); // Serial.println(lat.latitude, 5); // Serial.print(" lon DDDMM.MMMMM = "); // Serial.println(lon.lonitude, 5); Serial.print("lat degree = "); Serial.println(lat.latitudeDegree,6); Serial.print("lon degree = "); Serial.println(lon.lonitudeDegree,6);
 Serial.print("star userd = "); Serial.println(starUserd); Serial.print("alt high = "); Serial.println(high); Serial.print("sog =  "); Serial.println(sog); Serial.print("cog = "); Serial.println(cog); Serial.print("gnss mode =  "); Serial.println(gnss.getGnssMode()); delay(30000);}[/code]
The two Serial.print statements in bold have been added to make the output more readable.
Below is the output.
London UK is 51.5072° N, 0.1276° W
I am 120Miles NW of London so I cant be 2.24 degrees N i.e. 2.24 degrees above the equator!!
Either the library is in error or the device is.
userHeadPic VeeBee
jenna wrote:
Hi!
Sorry for the late reply.
We had fixed this issue and updated the library. pls try downloading the library and adding it to Arduino IDE.
2023-07-31 17:54:41
2023-07-18 19:09:59
Hi!
1.setRgbOn( )
2.Course over ground
The course over ground of the GNSS module is the angle corresponding to the direction of an object, starting from a reference direction (usually true north or magnetic north) and moving clockwise. The heading is expressed in degrees, ranging from 0 to 360.
userHeadPic jenna
VeeBee wrote:
I have seen the code for Rgb. I was asking what it was for, but I have found out already!
I know what “course over ground” means. It says it is calculated from two positions separated by time. If the position does not change it should be no course.
The main purpose of my post has not been addressed. Lat.direction returns the longitude direction and visa-versa.
I live at 52 degrees north of the equator i.e. my latitude is 52 N.  The device says 52 W it is wrong.
2023-07-18 20:04:01
