Forum >pH Meter ground loop
userHead BOON PIN.POH 2023-10-24 10:03:34 774 Views0 Replies
Has anyone tried and tested SEN0161-V2 Gravity pH meter? If I were to place a water level/moisture sensor into the same water as the probe, would it affect my reading? I heard there are ground loop issues when placing multiple sensors into the same fluid. Does the Signal Conversion Board help with this issue?
