Forum >Beetle ESP32-C3 getting error Load Access Fault
userHead Juan.Ortega 2023-10-31 00:45:57 914 Views0 Replies
Hello! I am working on a project using a ESP32-WROOM-32U and I wanted to upgrade it to the Beetle ESP32-C3 because it will allow battery charging and has a much smaller size.
When I tried to migrate my IoT project to this new board I started getting the error Load Access Fault while running the code. Could this be caused because some incompatibilities with some of the libraries used?
Thank you very much!
