Forum >Sen0257 unable to calibrate
TroubleshootingGravity
userHead Sjc.Colbrook 2023-11-15 08:59:44 777 Views1 Replies
Hi All.
I am using an Arduino Uno with the Sen0257 gravity water pressure sensor and have Downloaded the code, but i am unable to calibrate ie:- set off set as voltage is yo-yoing all over the place, also it doesn't seem to have any effect when i do change off set, what am i doing wrong.
cheers Sjc
2023-11-17 07:03:56
Have you tried the calibration code given in this wiki?
https://wiki.dfrobot.com/Gravity__Water_Pressure_Sensor_SKU__SEN0257
userHeadPic lia.ifat
