Forum >Dual Stepper Block on DFR0548
Troubleshooting
userHead carlos.gomez 2023-11-15 09:08:56 721 Views4 Replies
Hello, Ima having trouble with my DFR0548 board as I dont understand the use for the dualstepper block. I tried making a simple robot that moves using two steppers but as I was thinking of using the dual stepper block to move both motors it does only move one, only leds from M1 and M2 light up. Am I doing something wrong?
Im using a V2 microbit, I´m pretty sure everything is updated.
2023-11-16 04:52:47
Okay, I just discovered how they work… too much of a assle for me to be honest. Not sure why both stepper are not acting independent nor why trun is used instead of using steps or seconds. I guess they do work, just not optimal enough and the block is confusing.
userHeadPic carlos.gomez
2023-11-16 00:45:44
Im using a bench power supply, it does have more than enough power to power it. Also when using batteries I can move both motors at the same time but only using two “forever” blocks with each one having a single stepper block working, instead of using the dual stepper one (who also has a mispelling saying trun instead of turn).
My problem here is that if I want to make a turn I need to start using alerts and advanced programming tricks that confuse people and is hard to explain anything aside of that because the block does not want to work.
2023-11-15 13:10:18
Please check if your power supply to the DFR0548 board is sufficient for driving both stepper motors.
userHeadPic lia.ifat
