Forum >ORP probe with ADS1115
userHead PawelSmierciak 2024-02-28 09:06:31 466 Views3 Replies
hello
maybe someone could provide me some details how to calculate ORP with above hardware  and esp32
some part of my code:
ads.setGain(GAIN_ONE);
ads.begin();
orp_voltage = ads.readADC_SingleEnded(ORP_PIN) / 10;
how to calculate ORP level ?
right now i do it like this
    ORP = (orp_voltage / 5*1024)/1000;
but im not sure is it the good way
2025-03-06 21:50:05
HI, can you explain how did you calibrate the probe, not the signal converter? also i can't find information about the electrolyte in the reference probe?
userHeadPic Awais
2024-02-28 14:04:24
problem solved  ;-) short description and code for ADS1115 + SEN0464
first you need to calibrate ;-) more info on the webpage :
https://wiki.dfrobot.com/Gravity_Analog_ORP_Sensor_PRO_SKU_SEN0464
most important part:
Remove the ORP probe and use wire to short-circuit the S+ and S- pins of the ORP signal converter
use below code to read calibration value :
Adafruit_ADS1115 ads;
ads.begin();
voltage = ads.readADC_SingleEnded(ORP_PIN);
//you will have calibration value
calibration = voltage * 0.125;
and you will use it in your program to read data :
ads.begin();
orp = voltage * 0.125;
orp = orp - calibration;
userHeadPic PawelSmierciak
2024-02-28 09:24:02
just to clarify i got SEN0464  ORP probe
