Forum >MicroSD Module V1.0 incompatible with Netac 16 GB class 10
Troubleshooting
userHead Jeroen.Reelick 2024-10-11 03:55:00 442 Views0 Replies
The DFRobot MicroSD Module V1.0 is incompatible with Netac 16 GB class 10 microSD card.
CardInfo generates this error message:
Initializing SD card...initialization failed. Things to check:
* is a card inserted?
* is your wiring correct?
* did you change the chipSelect pin to match your shield or module?
Note: press reset button on the board and reopen this Serial Monitor after fixing your issue!
It works fine with a different microSD card of 8GB, class 4.
Is there a maximum to the size or speed of the microSD card?
Or is it just a freak card?
