Forum >Understanding Stepper Drivers Correctly
userHead Susan.Nan 2025-02-12 15:05:51 317 Views1 Replies
I have a project using a NEMA 23 stepper motor , which is a bipolar 4-wire connection and the spec sheet says it is rated at 2.8A/phase and 3.2V. I am using a DM542T digital driver which has a peak current of 42.A and an RMS current of 3.0A. I am using a 36V regulated Meanwell PS which has an output current of 5.9A. So I set the driver to the closest (peak 2.84A) to match my motor. Then I watched Bill's video on large stepper motors and was confused about something. Do we set the driver to "peak amps" or "RMS" and seeing as it is a bipolar motor do I really need to double the amperage (2.8 x 2 = 5.6A) to set it correctly?
I have other questions but I want to first clarify peak vs. rms and the total amps needed to get the setup right.
Thanks,
2025-02-15 22:15:36
For your setup with the NEMA 23 stepper motor and the DM542T driver, here are the key points to clarify:
1. **Peak Current vs. RMS Current:**
  - **Peak Current (2.84A):** This is the maximum current the driver will supply to the motor during operation.
  - **RMS Current (~2A):** This is the continuous current that the motor will effectively use over time, calculated as the peak current multiplied by 0.707 (RMS factor for a sine wave).
  When setting up your DM542T driver, **you should set it to the peak current** (2.84A) to match your motor’s 2.8A/phase rating. The driver will handle the RMS conversion internally.
 2. **Bipolar Motor Amperage:**
  - The **2.8A/phase rating** of your motor is per phase, and since it’s a bipolar motor, you **do not need to double the current**. The driver will handle both phases independently, so you set it to 2.84A (close to 2.8A) to match the motor’s specifications.
3. **Power Supply:**
  - Your 36V, 5.9A power supply is sufficient for this setup. The total current draw of the motor (2.8A/phase × 2 phases = 5.6A) is within the power supply’s 5.9A limit.
Summary:
  - Set the DM542T driver to **2.84A (peak current)**.
  - No need to double the amperage for a bipolar motor.
  - Your 36V, 5.9A power supply is adequate for the motor and driver.
Let me know if you have further questions!
userHeadPic R2D2C3PO
