Forum >Gravity 50A Current Sensor
Am I correct in assuming that I can use this sensor to measure current from a 48VDC battery to a bicycle hub drive motor? The maximum amperage that the motor can draw is 35amps. Supplying 5VDC to the 3 wire sensor connections should return me a 0.04mV per amp signal?
