Forum >SPI LCD Module (Arduino Compatible)
userHead jessy 2011-06-15 20:24:07 5094 Views2 Replies
I'm wanting to use the "SPI LCD Module (Arduino Compatible)" with and Arduino Mega 2560 and was wondering what the best way to interface. Can I just connect the two together through the SPI pins....or do I need additional hardware?
2011-07-19 07:48:06 Hi,
can I also connect this Display(DFR0091) to the Xboard-A via SPI?
Which of the ICSP Headers do I have to connect with the Display?
Thank You
Berry07
userHeadPic Berry07
2011-06-15 21:17:45 YES. You can simply wire the SPI pin from mega to LCD module. No extra hardware is required except 4 wires. userHeadPic R2D2C3PO
