Forum >Confusion with Gravity MOSFET Power Controller DFR0457
According to the connection diagram the pwm (green line) input is the top pin if you're holding the board with Vout pin at bottom. But the extension wires that came with it has the green wire on bottom (see attachment). Which one is it?
2018-04-05 01:49:37 The diagram in the wiki is wrong, the green line should on the top and GND at the bottom
robert.chen
