Romeo - a Robot Control Board with Motor Driver (Compatible with Arduino)
$24.90
SKU: DFR0004
  • $24.00 2+ items
  • $23.50 5+ items
  • $23.00 10+ items
Romeo family is an All-in-One Robot control board especially designed for robotics applications from DFRobot.  It benefits from the Arduino open source platform, it is supported by thousands of open source codes, and can easily be expanded with your shields. The integrated 2 way DC motor driver and wireless socket allows you to start your own robot project immediately without the need for an additional motor driver.  Not just has the motor driver, Romeo is also designed to have extra power for servos which need more current.
Romeo is also featured with DFRobot's standard 3 Pin-out designed and compatible with Gravity series sensors and actuators. Hundreds of sensors are now plug-play with Romeo.
This is the first member in Romeo family that is born in 2009. It is not only the very first Arduino compatible robot controller but also the first Arduino-derived board in the market. The current version of Romeo is based on Arduino Uno. It has built-in 2x2A DC motor drivers and socket for bluetooth / APC220 Radio Communication Module communications. The integrated io sensor pinout allows it connect hundreds of different Gravity compatible sensors and modules. It has servo connector which is a plug & play. It is the ideal controller to build your own robot
Romeo All in One Robot Controller Board Review by Arnab Kumar Das
Tank Robot Project using the Devastator metal chassis!
DFRobot Arduino Compatible Microcontroller Selection Guide
Model DFRduino UNO DFRduino Leonardo DFRduino Mega2560 DFRduino Mega1280 Romeo V1 Romeo V2 Bluno Wido
SKU DFR0216 DFR0221 DFR0191 DFR0003 DFR0004 DFR0225 DFR0267 DFR0321
Processor ATmega328 ATmega32u4 ATmega2560 ATmega1280 ATmega328 ATmega32u4 ATmega328 ATmega32u4
Board Type Arduino UNO Arduino Leonardo Arduino Mega 2560 Arduino Mega Arduino UNO Arduino Leonardo Arduino UNO Arduino Leonardo
Operating Voltage (Voltage / Input Voltage) 5 V/7-12 V 5 V/7-12 V 5 V/7-12 V 5 V/7-12 V 5 V/7-12 V 5 V/7-20 V 5 V/7-12 V 5 V/7-12 V
CPU Frequency 16MHz 16MHz 16MHz 16MHz 16MHz 16MHz 16MHz 16MHz
Analog Ports  (Input / Output) 6 / 0 12 / 0 16 /  0 16 / 0 6 / 0 12 / 0 6 / 0 12 / 0
Digital Ports (IO/PWM 14 / 6 20 / 7 54 / 15 54 / 15 14 / 6 20 / 7 14 / 6 20 / 7
EEPROM[KB] 1 1 4 4 1 1 1 1
SRAM[KB] 2 2.5 8 8 2 2.5 2 2.5
Flash[KB] 32 32 256 128 32 32 32 32
USB Interface A-B Micro A-B A-B A-B Micro Micro Micro
UART 1 2 4 4 1 2 1 2
Dimension 75 × 55mm 75 × 55mm 108 × 54mm 108 × 54mm 100 × 80mm 89 × 85mm 75 × 55mm 75 × 55mm
Price $19.90 $19.90 $24.90 $14.00 $29.50 $34.95 $24.90 $29.90
*A low-cost controller board designed for domestic Arduino fans. Full compatible with Arduino UNO R3.
*Suitable for Arduino Beginners.
*Low-cost mian controller board. The main difference from the official one is that this board offers XBee socket and SPI directly-plugged interface, making the best of UART ports.
*DFRduino Mega 2560 comes with plenty of IO ports, 54 digital ports, 16 analog ports, and 4 UARTs.
*Applicable to large projects that requires many sensors.
*Mega1280  has as many IO ports as Mega256, but comes with a smaller Flash. Besides, its  price is lower than Mega2560.
*Suitable for low-cost projects requiring many sensors.
*Romeo V1 is specially designed for robot fans. It integrates motor driver, all sorts of communication ports, IO expansion port and so on.
*Extremely suitable for robot fans.
*The only difference between V1 and V2 is that Romeo V2 adopts ATmega32u4 chip, which provides 2 UARTs, convenient for wireless communication.
*For robot fans to build up projects with wireless communication.
*The first Arduino compatible controller board that integrates Bluetooth 4.0, bring much more flexibliy and possibility for Android and IOS mobile development.
*For Android and IOS mobile App BLE developers.
*Integrated CC3000 wifi  core and SD card function. Can store a large number of collected data. Compared with Wifi shield, wido is more lightweight and low-cost.
*For IoT developers.
  • DC Supply:USB Powered or External 7V~12V DC
  • DC Output:5V /3.3V DC and External Power Output
  • Microcontroller: Atmega328
  • Bootloader: Arduino Uno
  • Compatible with the Arduino Uno pin mapping
  • 8 Channels 10-bit Analog I/O
  • USB interface
  • 5 key inputs
  • Auto sensing/switching power input
  • ICSP header for direct program download
  • Serial Interface TTL Level
  • Support Male and Female Pin Header
  • Integrated sockets for APC220 RF Module and DF-Bluetooth Module
  • Three I2C Interface Pin Sets(two 90°pin headers)
  • Two way Motor Driver with 2A maximum current
  • Gold plating pcb board
  • Size:90x80x14mm(3.54"x3.15"x0.55")
  • Weight:60 gram
Projects
Project 1. Summer inspiration-DIY automatic curtain lift
List of hardware:
Project 2. DFRobot AutoEco System takes care of your garden.
By following this project it will help to grow a vegetable garden, and automate some other processes in our house along the way.
List of basic hardware to setup an AutoEco Sys:
  • 1. Romeo
  • 2. X-Board
  • 3. Light Sensor
  • 4 .Gas Sensor
  • 5 .Motion Sensor
  • 6. Tempreture&Humidity Sensor
  • 7. Waterproof temperature sensor
  • Review
    Thushara.Rathnayake Jul 03, 2021
    Very nice control board. Easy to connect all the peripherals with jumper wires. Excellent quality connections which is important when a robot is moving.
    kyle.benson May 18, 2023
    Very fast shipping. Thank you!
