DFRduino UNO R3 - Compatible with Arduino Uno
$12.90
SKU: DFR0216
DFRduino Uno V3.0 from DFRobot is a physical world computing board of small size for academics or development . It is a simple microcontroller board fully compatible with Arduino UNO R3 and Arduino IDE open-source development environment. This environment implements the Processing / Wiring language. Arduino can be used to develop stand-alone interactive objects or can be connected to software on your computer (e.g. Flash, Processing, MaxMSP). The open-source IDE can be downloaded for free (currently for Mac OS X, Windows, and Linux).
This board features the ATmega16U2 programmed as a USB-to-serial converter. An added bonus is that our DFRduino is still using the DIP package AVR Chip. You could remove it to update or reprogram the chip's firmware, or even to place it on a finished, more compact project. The cool thing about our new DFRduino microcontroller is that the headers use different colors to feature I/O ports of different types:
  • Red for Power Section.
  • Blue for Analog I/O.
  • Green for Digital I/O.
These colors match our sensor cables. This makes it really easy to figure out where to connect sensors, or to identify which side is Analog (blue) or Digital (green).
"Arduino Uno" is a microcontroller board based on the ATmega328. It has 14 digital input/output pins (of which 6 can be used as PWM outputs), 6 analog inputs, a 16 MHz crystal oscillator, a USB connection, a power jack, an ICSP header, and a reset button. It contains everything needed to support the microcontroller; simply connect it to a computer with a USB cable or power it with a AC-to-DC adapter or battery to get started.
This board added SDA and SCL pins that are near to the AREF pin and two other new pins placed near to the RESET pin, the IOREF that allow the shields to adapt to the voltage provided from the board. In future, shields will be compatible both with the board that use the AVR, which operate with 5V and with the "Arduino Due" that operate with 3.3V. The second one is a not connected pin, that is reserved for future purposes.
DFRobot Microcontrollers compatible with Arduino
DFRduino UNO R3 DFRobot Leonardo with Xbee Socket DFRobot Mega 2560 V3.0 Romeo V2- an Arduino Robot Board Romeo - an Arduino Robot Control Board with Motor Driver
Name DFRduino UNO DFRobot Leonardo DFRobot Mega 2560 Romeo V2 Romeo
SKU DFR0216 DFR0221 DFR0191 DFR0225 DFR0004
Microcontroller ATmega328p ATmega32u4 ATmega2560 ATmega32U4 Atmega328
Working voltage 5V 5V 5V 5V 5V
CPU Frequency 16MHz 16MHz 16MHz 16MHz 16MHz
TIO ports / PWM 6 / 14 7 / 20 54 / 15 20 / 7 14 / 6
Analog inputs 6 12 16 12 8
UART 1 2 4 2 1
I2C 1 1 2 3 3
SPI 1 1 1 1 1
Interrupt pins 2 2 2 2 2
EEPROM[KB] 1 1 4 1 1
Flash[KB] 32 32 256 32 32
SRAM[KB] 2 2.5 8 2.5 2
USB
A-B USB cable
micro USB cable
A-B USB cable
micro USB cable
A-B USB cable
Dimension 75*55*15mm 75*55*15mm 100*53*15mm 89*84*14mm 90*80*14mm
Vin 7-12V 7-12V 7-12V 7-12V 7-12V
Price $19.9 $19.9 $24.9 $34.95 $29.5
Weight(g) 45 50 70 80 80
IDE version Arduino 1.0 and above Arduino 1.0 and above Arduino 1.0 and above Arduino 1.0 and above Arduino 1.0 and above
Feature DFRduino UNO is fully compatible with Arduino UNO R3,suitable for Arduino beginner and hobbyists DFRobot Leonardo is a low cost controller, integrated with Xbee and SPI. Suitable for low cost and communication demand of hobbyists DFRduino Mega has 54 digital pins and 16 analog pins, 4 UART channels. Suitable for demands of vast sensors Use ATmega32u4, 2 serial ports. Intergrated with Xbee socket and motor drivers Microcontroller with motor driver, communication ports, IO expansion ports, it can be used as the main controller of robots
  • Microcontroller: ATmega328 (DIP package)
  • Operating voltage: 5V
  • Input voltage: No external power supply needed when connected to USB or external 7V~12V DC input
  • Output voltage: 5V DC output and 3.3V DC output
  • Clock speed: 16 MHz
  • Bootloader: Arduino Uno
  • Supports USB interface protocol and power supply (no external power source needed)
  • Supports ISP download function
  • Digital I/O pins: 14 (6 are PWM outputs)
  • Analog input pins: 6
  • DC current per I/O Pin: 40mA
  • DC current for 3.3V Pin: 50mA
  • Flash memory: 32 KB (ATmega328)
  • SRAM: 2 KB (ATmega328)
  • EEPROM: 1 KB (ATmega328)
  • Dimensions: 75 x 54 x 15 mm (2.95 x 2.13 x 0.59 inches)
  • Environmental Friendly: Complies with Rohs standards
  • Projects
    1. Project: Sunflower - Arduino Solar Tracker
    Introduction: 'The Sunflower' is an Arduino based solar tracker which will increase the efficiency of the solar panel while charging.
    2. Project: Zelda Song Player
    Introduction: Assemble an Arduino Uno-based device to recreate an N64 controller to play the first six songs from the Legend of Zelda: Ocarina of Time!
    3. Project: E-Paper display with Arduino from DFRobot
    Introduction: In this video, we learn how to use an E-Paper display with an Arduino board.
    4. Project: CAT-BOT
    Introduction: I used to dream of my kitty talking to me and now I am going to make my toy kitty react to my actions and even CHAT WITH ME!
    5. Project: How To Make LED Kitchen Sink Lights with a PIR Sensor, Arduino, and 3D Printing
    Introduction: I wanted to brighten up my kitchen and install some lights under the sink, but rather than buy a pre-made LED kit, I decided to make my own. Let me show you how I made this!
    • DFRduino Uno V3.0  x1
    Gun Away
    Projects Gun Away
    RoniBandini
    Feb 18, 2025
    How to use wind speed/direction transmitter on Arduino and micro:bit? ——RS485 to UART
    Projects How to use wind speed/direction transmitter on Arduino and micro:bit? ——RS485 to UART
    Meimei
    Jul 01, 2023
    Arduino UNO Project
    Projects Arduino UNO Project
    RiverTrue
    Feb 27, 2023
    Make a TDS Detector for Water Testing Experiment
    Projects Make a TDS Detector for Water Testing Experiment
    Frances
    Sep 15, 2022
    May 23, 2022
    DFRobot Best Sellers List
    May 17, 2022
    Dave.Kriedeman Feb 20, 2021
    wajdi. Oct 21, 2022
    Very good as description
