Arduino DUE - An Arduino Microcontroller Board
$56.00
SKU: DFR0220
The Arduino Due is a 32-bit microcontroller board with an ARM Cortex-M3 processor, featuring 54 I/O pins, 12 analog inputs, USB-OTG, and runs at 3.3V.
Purchase this product and earn 560 reward points, which are tied to VIP membership program. Learn More >
The Arduino Due is the newcomer microcontroller board in the Arduino boards family. It's the first board based on a 32 bit ARM core processor, the Atmel SAM3X8E ARM Cortex-M3 MCU, that improve all the standard Arduino functionalities and add more new features.
The Arduino Due has 54 digital input/output pins (of which 12 can be used as PWM outputs), 12 analog inputs, 4 UARTs (hardware serial ports), an 84 MHz clock, a USB-OTG capable connection, 2 DAC (digital to analog), 2 TWI, a power jack, an SPI header, a JTAG header, a reset button and an erase button. There are also some cool features like DACs, Audio, DMA , an experimental multi tasking library and more.
The Due has two usb connectors, the one with the micro-usb AB connector is the native one capable to act as an USB host, that means you can connect compatible external usb peripherals to the board, such as mouse, keyboards, smartphones. While the other USB port with the type B connector is intended for debugging purposes.
Note:
  • To compile code for the ARM processor, you'll need the latest version of the Arduino IDE: v1.5.
  • Unlike other Arduino boards, the Arduino Due board runs at 3.3V. The maximum voltage that the I/O pins can tolerate is 3.3V. Providing higher voltages, like 5V to an I/O pin could damage the board.
    • Microcontroller AT91SAM3X8E
    • Operating Voltage 3.3V
    • Input Voltage (recommended) 7-12V
    • Input Voltage (limits) 6-20V
    • Digital I/O Pins 54 (of which 12 provide PWM output)
    • Analog Input Pins 12
    • Analog Outputs Pins 2 (DAC)
    • Total DC Output Current on all I/O lines 130 mA
    • DC Current for 3.3V Pin 800 mA
    • DC Current for 5V Pin 800 mA
    • Flash Memory 512 KB all available for the user applications
    • SRAM 96 KB (64 + 32 KB)
    • Clock Speed 84 MHz
    • Arduino DUE x1
    Out Of Stock
    $56.00
