SELECTION GUIDE ArduinoGravitymicro:bit
DFRobot Motor Drive Expansion Board Selection Guide
DFRobot Dec 25 2018 260912
Product Name
2x1A DC Motor Shield for Arduino
micro:Driver - Driver Expansion Board
Gravity: Dual Bipolar Stepper Motor Shield for Arduino (DRV8825)
Quad DC Motor Driver Shield for Arduino
Gravity: IO Expansion & Motor Driver Shield
Gravity: 2x2A Motor Shield for Arduino Twin
TMC260 Stepper Motor Driver Shield For Arduino
2x2A DC Motor Shield for Arduino
Figure
SKU
DRI0001
DFR0548
DRI0023
DRI0039
DFR0502
DRI0017
DRI0035
DRI0009
Chip
L293B
HR8833
DRV8825
TB6612FNG
TB6612FNG
L298
TMC260
L298P
Operating voltage
5V DC
3.3V/5V
2.7~5.5V
2.7~5.5V
5V
5V
5V
Motor drive voltage
7-12V DC
3.5~5.5V DC
8.2-45VDC
2.5V-13.5V
12V (peak value)
4.8 ~ 35V
40V max
6.5~12v(VIN Power Supply),4.8~35V (External Power Source)
Maximum drive current
1A each way
1.5A
1.6A
1.2A continuous current (per channel) 2A (continuous pulse) 3.2A (single pulse)
up to 2A/channel
up to 2A per motor coil
2A
Motor drive using pins
PIN4/5/6/7 (Arduino Controllor)
D4,D5,D6 D7,D8,D12
D3,4,5,6,7,8,11,12
D4 D5 D6 D7
D10,11,12,13
Pin 4,5,6,7 are used to drive two DC motor
Dimension
56x57mm
63 x 58mm
83*55*25mm
52mm * 53mm
68.5mm×53.3mm
56x57mm
55x55mm
Weight (g)
60
64
48
24
36
35
35
60
Frequently used With
FIT0565/FIT0520/ FIT0450/FIT0492/ N20 Series​
FIT0278/FIT0503
FIT0278/FIT0503
Key Features
With motor indicator
8-way servo interface DC motor x4/stepper motor x2(multiplexed with motor interface)
Full step, 1/2, 1/4, 1/8, 1/16, 1/32 step mode
High-speed drive capability, can drive ordinary 2-phase stepper motor to 5000RPM, and drive quad DC at the same time
Integrated XBee Slot, XBee, WiFi Bee, Bluetooth Bee, IIC.
Mirrored version of DRI0009. Drive pins: 10, 11, 12, 13 Not compatible with IO expansion board V7.1. The control port is four, which reduces the overhead of the Arduino digital ports, and easy to program.
Suitable for driving bipolar stepper motors. SPI serial bus control or STEP/DIR signal control. Controllers such as Mega with full port expansion. 256 times microstep subdivision.
Use mirror motor to drive DRI0017 to aviod the conflicts . Support PWM speed control. Support PLL advance speed control
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
