Using the Beetle ESP32 - C3 with the Gravity Lightning Distance Sensor General DFR0868
Programming beetle esp32 c3 in ESP-IDF for serial input via Serial Monitor Firebeetle ESP32/8266DFR0868General
Beetle ESP32 - C3 default board config General Firebeetle ESP32/8266DFR0868
SPIFFS Arduino example for ESP32-C3 General DFR0868Firebeetle ESP32/8266
