SEN0386 datasheet with serial protocol and explanation on negative number encoding format General ArduinoSEN0386
Library for STM32 from sensor serial 6-axis accelerometer SEN0386 General SEN0386
ADC bit and Changing the full scale in Serial 6-Axis IMU Module General SEN0386
Serial 6-Axis Accelerometer x1 General SEN0386Arduino
Serial 6-Axis Accelerometer Data Frame General ArduinoSEN0386
Serial port problem with SEN0386 gyro unit General SEN0386
SEN0386 built-in filter ArduinoGeneral SEN0386
