What is the specification of the speaker interface? What parameters of speaker are supported? FAQDFR1154
Can the EdgeImpulse object classification model be customized? FAQDFR1154
What are the parameters of the infrared fill light? FAQDFR1154
What is the maximum supported size of TF card? FAQDFR1154
- 3 Changing behavior of SEN0366 laser distance sensor .. is it possible?
- 8 Maqueen Plus V2 + Mechanic Beetle not usable
