DFR1154 : Recording and Playing Audio DOESN'T WORK TroubleshootingDFR1154
DFR1154 - ESP32S3 Ai Cam - How can I enable the InfraRed LEDS? General DFR1154
Cant connect ESP32-S3 AI Camera to wifi :-( General DFR1154
ESP_I2S.h: No such file or directory TroubleshootingDFR1154
DFR1154 AI Camera : ChatGPT/DeepSeek Multimodal Demo TroubleshootingDFR1154
In the Arduino IDE what board to you pick for the new "ESP32-S3 AI Camera Module " How to selectArduinoDFR1154
What is the specification of the speaker interface? What parameters of speaker are supported? FAQDFR1154
Can the EdgeImpulse object classification model be customized? FAQDFR1154
What are the parameters of the infrared fill light? FAQDFR1154
What is the maximum supported size of TF card? FAQDFR1154
